How much weighs your truggy brushless ?
Pierre
Pierre's Avatar
How much weighs your truggy brushless ? - 03.24.2007, 03:20 PM
Hello has all
I find that my truggy brushless is heavy, how much weighs your?
thanks
bye
  Send a message via MSN to Pierre
Sower
Sower's Avatar
03.24.2007, 05:17 PM
Bonjour! Welcome to the forums! I haven't weighed mine yet, but mine's pretty light. What truggy do you have, and what's your brushless system? Any photos?
Pierre
Pierre's Avatar
03.24.2007, 05:25 PM
my truggy is a hellfire witch warrior 9920 + feigao 8XL + 16 intellect 3800
It is almost finished
thanks
Serum
Serum's Avatar
03.24.2007, 05:40 PM
i would guess 4.5 kg?
Pierre
Pierre's Avatar
03.24.2007, 06:21 PM
no 5.2kg :002:
AAngel
03.24.2007, 11:09 PM
I have a Losi Muggy that I converted with a MM/Feigao 7XL. With a 4S2P 6Ah pack, it weighs around 13lbs. It's pretty heavy, but you wouldn't know it watching it run. It wheelies and jumps like an animal.
03.24.2007, 11:13 PM
But what kind of animal? Some animals don't move fast or jump far. ;)
Serum
Serum's Avatar
03.25.2007, 04:29 AM
No, while a hippo might look too big, it does a good 30mph on a speedrun.. Don't know how it jumps though.. (i guess it's the landing that's the killer)
Piere;
Considered going lipo?
What tires/wheels are you using?
Mr.lst
03.25.2007, 05:38 AM
I would think that is lands just fine, team losi does alot of homework before releasing their products and that is close to stock weight with a nitro engine in it.
Pierre
Pierre's Avatar
03.25.2007, 05:56 AM
my hellfire is full origin
You do not think that with the 8XL it will have not many speed?
Erkan
03.25.2007, 06:09 AM
o.k. my Outrunner Hf iss org.4,4 KG Heavy ! By using Lipo RC Battery I will earn 100 Gramm´s less ! The 8 s /123 Li/FE Zells are only 600 Gramm´s light !
I would like to place two 4800er4s Packs into a 8 S but in the org. Hellfire there is not enough Space to Place them on a good Posizion ! I want to build a komplet Chassis, with is 3 CM longer and the Big lipos will fit in !
best Regards Stefan
AAngel
03.25.2007, 11:40 AM
If I was to say what sort of animal my Muggy is, I would have to say that it's a big FAT cat. It is fast, jumps well, lands well, and is pretty fast. It is faster than any nitro truggy I've seen.
It is heavy, but there is also a lot I can do to shed weight. As the opporunities arise, I will be adding carbon fiber and getting rid of the 40 series wheels/tires that also add a lot of weight. I do, however, have to say that the stock tires provide good traction and are wearing well on concrete.
Mr.lst
03.25.2007, 11:44 AM
I would not worry about the weight until you start to race I am sure it is balaced very well
Pierre
Pierre's Avatar
03.26.2007, 04:26 PM
my car :
what do you think about it ?
Serum
Serum's Avatar
03.26.2007, 04:38 PM
Looks good Piere; but i have got a tip for you;
use a 46t kyosho spur, that way you can flip the differential; that long pinion is a killer for your motorshaft! if you can't do the 46t (due to gearing limitations) make an extra slot in the chassis.
I would try to make the wires on the controller a bit shorter.
