MetalMan
MetalMan's Avatar
04.05.2007, 12:53 PM
Thanks for the comments, guys!
Serum - I decided to try something a little different with the tires. Both wheels are 17mm hexes :005:.
AAngel - I have yet to see a spike over 120amps. Sometimes the voltage will be at a lower point, like 11.5v (down from 12.5v) at a 120amp spike, even when the battery still has a lot left in it. So, it appears it isn't capable of going over 120amps.
Dafni - It was fine without the body :). Besides, both of my bodies for it have large cracks in them :(.
luvsrc - 5s A123 is 16.5v, 5s Lipo is 18.5v. There's a bit of a difference, but 16.5v is fine with me. I have yet to see my 540C 7XL get above about 150 deg. F, in the street or on the track. I do punish it pretty hard on the street (as you can somewhat see). With the Maxx mashers the 7XL got to about 140, and with the 1/8 buggy Road Rages it got to about 125. The Feigao 540C 7XL is pretty much the same power as the Hacker 7XL, but the Hacker 7XL should be slightly more efficient (I don't think it's enough to justify the almost doubled price).
elegal - The gearing was the same for the MT tires and for the buggy tires. I was surprised that it was going so fast even with the smaller tires.
Originally Posted by Serum
nice thing about lipo's you can have more runtime (capacity) at the same weight.
Yeah, that's one reason why I'm going Lipo in my Hyper 8.
The A123s do have one major advantage, though. They aren't sensitive to overvoltage like Lipos are. Because of this, I haven't felt the need to balance either of my 5s2p A123 packs in a while. I've gone through about 5 cycles each since I last balanced them.
Serum
Serum's Avatar
04.05.2007, 12:55 PM
I like the GRP 17mm wheels.. they come glued with moulded foams inside. They look an awfull lot like the wheels used on the 8ight 8t..
MetalMan
MetalMan's Avatar
04.05.2007, 12:57 PM
Serum, do you mean these ones?:
http://www2.towerhobbies.com/cgi-bin...gy&FVPROFIL=++
Serum
Serum's Avatar
04.05.2007, 01:07 PM
Exactamundo!
They look like the real deal to me.
Moulded foams.. GRP makes good rubber. and i've seen a movie some dudes where banging on them with a big hammer..
after some searching;
http://video.google.co.uk/videoplay?...TJPProductions
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
04.05.2007, 02:25 PM
Those are nice rims/wheel set. What size hex do they use? Kinda looks like 17mm.
GorillaMaxx360
GorillaMaxx360's Avatar
04.05.2007, 07:51 PM
they are 17mm nice strong rims
AAngel
04.05.2007, 08:14 PM
MM, I have to comment again, that the vid was nice. Your truck seems to run very smoothly without any hiccups. That compro looks like it's doing its job, which is a relief to me, since I just ordered one instead of the Quark.
Gustav
Gustav's Avatar
04.05.2007, 08:48 PM
Exactamundo!
Now that's some strange behavoir,the trumpet was nice though.so the GRP is quality gear then,that's good to know.What 17mm adapters do we like for maxxs,revos n' suc h?
DickyT
04.05.2007, 09:03 PM
Nie truck Metal Man. That thing moves!
Those GRP wheels are crazy...
squeeforever
squeeforever's Avatar
04.05.2007, 09:10 PM
The Ofna's are probably your best bet, unless you wanna go with the RD Racing knuckles w/8mm axle kit and run buggy hubs.
Romster
04.05.2007, 10:24 PM
Metal man nice video and nice weet set-up!!
Love the Jumps!!
Romster
04.05.2007, 10:25 PM
Sweet set-up!
MetalMan
MetalMan's Avatar
04.05.2007, 10:27 PM
I would say it runs pretty well. Even though it's the version without heastinks (it's wrapped in heatshrink with only heat spreaders), it runs at a pretty good temperature. In the same truck the MM needed a fan to keep it from thermalling. One problem with this ESC is that the BEC chip burnt out, and so now it sends the main battery's voltage to the receiver. When that happened, it smoked the receiver and servo... But with a RX pack it runs just fine. I might take the shrinkwrap off and add heatsinks to it to make it run even cooler.
neweuser
neweuser's Avatar
04.05.2007, 11:38 PM
Very nice MetalMan. I really like your Revo. The MGM is it? Seems to do very well! I likes!
MetalMan
MetalMan's Avatar
04.06.2007, 12:34 AM
Yeah, it's the MGM that arrived at my door as a replacement for one I sent in 6 months before I got this one!
