Revo 22.2v
Eccentric
Revo 22.2v - 05.19.2007, 10:47 PM
Well it's not really High Voltage so I can't call it Revo HV so I'm calling it Revo 22.2
I started with a new truck (didn't own a Revo).
RC-Monster Revo motor mount
12XL motor
CC 110HV ESC w/ PiStix adapter
UBEC for power
EVO-20 battery (great deal at 40% off)
Steering HiTec HS-5955TG
Still has 2-speed w/ reverse and mechanical brake. Using 3rd channel for the reverse servo and a y-split to do the brakes and ESC.
It's still very light on it's feet but it's a porker now at 12.06lbs.
I had an idea of the direction I wanted to go with the truck and what parts to get. Based on the advice given here and else where on the net. I didn't plan on buying it all at once but most of it went on clearance the day I was going to make an order so I got all the parts I wanted. A few things are left out of the picture and the Vantage chassis and center diff/rear brake are for a waterproof Revo I'm planning. And you guys are right 23mm Proline adapters are less then impressive.
This is how the truck looked during the test fitting. There is not much clearance between the body and the ESC which worried me. But after running it is going to be fine till the cage comes.
After a couple runs still going running great, only minor things, popped a ball out of the RPM carries (?) and had the set screw come loose on the pinion. The ESC is just warm and the motor isn't much more.
I planned on using Husky straps but couldn't find them so I used zip-ties. I have them now and will put them on this week.
This rat's nest is temporary till more parts come.
I made the battery box out of some.220" (5.588mm) polycarbonate that I had. It doesn't form as easy as I thought it would but it came out alright.
The body fits other then the filler opening.
