Go Back   RC-Monster Forums > Questions and Answers > Pre Sales Questions
luvsrc
RC-MONSTER BRUSHLESS FANATIC
luvsrc's Avatar
05.20.2007, 07:38 AM
Originally Posted by Patrick
Luvsrc is your motor the finned version? If it is, did you have to grind the fins or modify anything else to get the 16t pinion to fit?
Were you using revo diffs in yours? If you were, then 18t pinion with buggy gears (what GrorrilaMaxx360 said he's using) would be almost the same ratio as revo diffs and 16t pinion.
There is a 65t that will fit the strobe with a bit of modifying (I'm not sure exactly how much, I haven't had to do it), but you'll probably also have to extend the adjustment slot in the stock motor plate, because it puts the motor so far away. I think that spur is for a ofna pirate, but I'd check with someone else first, like Mike and I think squeeforever knows as well.
yes I'm using the finned version my 16 tooth pinion on my standard revo diffs is the lowest pinion i can fit in my gorillamaxx single speed tranny without grinding the finns which I will not do it anyways, you can use the buggy version or even the truggy version which lowers the gear ratio more so all you have to do is put a bigger pinion on it, the 18/51 on buggy gears will be the same with my 16/51 on a standard revo diffs
Brushless Jammin Truggy on NEU 1515 2.5 D on Monster mamba max with maxamps 5000mah 6s Lipo
Gorillamaxx Revo CF version on Mamba maxx ESC with NEU 1515 1Y on Maxamps 4s 8000mah Lipo
