09.14.2007, 12:56 PM
The revo gear will fir but will be too small and require a tiny pinion
Depend, if the revo 40 tooth mod1 is the same diameter than the stock stampede 84 tooth 48 pitch, no prob for gearing, with a mod1 13 tooths pinion, it's suppose to be not to bad?? I'am wrong???
I've did the test on R/C calculation and this is what i've experience.
Ok, I would try that. The gearing you mentioned will put your pede near 50mph if you run 3s lipo on the 9l. As long as your pede is light the l motor should run ok, not too hot. I would test that setup by temping the motor and esc frequently on the test run.
