lipomax
02.17.2005, 01:56 AM
Just got two of the 3s 3200 packs. Sorry Mike - I got them from Tower for lower than my 3s 3100 12 C polyquest packs!!!! They had this 30 dollar discount on 199.99 or something so I had to try them. Based on numbers, they're slightly larger than the Polyquest. The Polyquest are at 7.5 oz per pack while the Kokam is at 10 oz per pack (more in comparison to 14.8 volt 3100 polyquest) so energy density is LOWER than polyquest, but discharge rate is higher. Will have to see it in my emaxx with eagle tree to see the voltage drop under discharge...
I'll be using 6s 3200 in my Emaxx... or try that 12000 kv Motor again in my TC4. Last time I used the 1515 5 turn with 11.1 volts, it was pulling over 100 amps and voltage drop was down to 5.0 volts!!!!!
