highflier
Emaxx- FLM wannabe
11.18.2007, 11:28 PM
Well The build is coming along. Taking a lot more time then I thought. I should cut a few hex wreches so that I can put them in the power drill. I replaced all the A-Arms with RPM and shock towers are RPM also. That took sometime. Also since this is the first time I am doing this major disassemble, it is going slow as I am still learning best ways to dissasseble and reassemble.
I have seen a few posts about top and bottom of the chassis, To me it appears that it only has one top side as there is some groves milled in so that the front and rear ends bolt in a grove. However I can only get the antenna mount to go onto the bottom :(.
Anybody else have that issue? Easiest way to fix???
one more question. The Read Dogbone is a little loose, On my old RC-10t there was a spring to ensure it did not vibrate, Should I put some fuel tubinng or something in the drive cups?
Also if I deside to lock the tranny into 2nd gear, Does anybody have pics of a dual steering servo setup? I have the Proline Tmaxx steering kit. Had it in the old chassis, Had to cut plastic for that, Fits in the FLM like a glove :)
If I was to do it again I think I would upgrade the bulks also. It's going to be PIA if/when one breaks.
Thanks in advance for any answers.
Highflier
