Attila
08.16.2005, 06:39 PM
Originally posted by Dafni
Atilla: I agree with Serum. A basher truck like the Savy should be fun with the auto tranny. Why not keep both gears open?
With the the automatic transmission I loose the reverse gear...
Originally posted by Serum
16 cells you could use the 9920 with the 10L or the 7XL or 8XL, using the automatic transmission. (this RULES!!!!) (be sure to get the heavy duty 2nd gear mod)
If you plan on running 2nd gear, i would use the 8XL.. (with a 16/49 gearing it is really quick (40 mph))
Which "heavy duty 2nd gear mod" do you mean?
2nd gear fixed could be an option. But with an 8XL on 16 cells I am always below the sweet spot (~33000 rpm). Something to care about??
The more I play with the speedtable the more I like the BK 20XL/7 or maybe the BK 20L/10. The L of course draws less amps, which means longer run time. But is an "L" strong enough for a Savage???
BTW: Why does a Feigao 7XL has a kv of 2382 and a BK 20XL/7 a kv of only 2145? I thought that they are more or less identical...?
OK, when you have to choose one of these setups, which one would you prefer? (always on 16 cells and with a BK 12020 controller)
a) BK 20XL/7 (kv: 2145, about 90-95 amps)
b) BK 20L/10 (kv: 2212, about 60 amps)
Speed is for both setups nearly the same:
1st gear: 16/49= 30 mph or 18/49 = 33 mph
2nd gear: 16/49 = 42 mph
Again: is an "L" strong enough for a Savage? And does it has more torque than a stock .25 nitro Savage?
Thanks!
-- Dave
