othello
HV basher
12.12.2007, 07:47 PM
>Maybe we should both take this up with Kontronik? Would be nice to get a fix from them. :) I would guess it's just a firmware issue...
A german guy did exactly this and had some talk with kontronik. But he was only told to use the "car" specific controllers and that he was the only one experiencing this behaviour (he used a Jazz 80-6-18). Seems to me they will not be too cooperative about this. But when more and more people will complain they might change their firmware. But you mainly see those ESC in air/heli application.
I too saw regenerative braking in my logs: graph. The eagletree micropower does not get confused by the current flowing to the battery when braking. Weird that the DPR resets it's zero point to 26A. Average Watt and amperes are hard to tell this way. 1077 watts average would dump your battery rather quickly ;-))
I can absolutely confirm your findings but obviously got used to this behaviour (i drive Jazz ESCs in 1:8 conversions since half a year) especially as i mainly drive on loose surfaces with quick throttle position changes where it does not get so obvious as if you would drive on a high grip surface with gentler throttle impulses. It sure would be better if the ESC would not kind of brake to get from 70% throttle to 30%. It is worth a try to shoot kontronik a mail about this but i do not think there is an easy way to change this behaviour by ourselves. It sure implies a firmware change.
The more traction, the higher your Amp Peaks will be and your ESC and motor will heat up accordingly. My findings were that even if you see almost the same average Amps on different tracks, temperature levels of the ESC and motor are quite different when you drive on loose or on hard packed tracks. On grass i pulled up to 2,27KW (95A with 10s A123). So the jazz is up to the task and is able to provide more than 65A but will heat up easely when used constantly up to this power levels. No thermal shut down as of yet but I might need a small heat sink especially when ambient temps will rise here during summer. I never needed one when i used the jazz 55 in my lighter buggy with power levels up to 1.7KW, but the truggy needs more power (obviously) and thus heats up the ESC quicker.
140F is more than i expected from this big motor, but it is not critical at all. What was your outside temp when you drove?
EDIT: can't see the firmware version, as i mounted my Jazz with the cooling plate facing upwards.
