Thread Tools Rating: Thread Rating: 15 votes, 5.00 average. Display Modes
sikeston34m
sikeston34m's Avatar
12.14.2007, 02:23 AM
Originally Posted by ilpufxit View Post
I've been following this thread as I continue to experiment with my e-maxx. I'm starting to think that a centrifugal clutch might be just the answer. If the outrunner's only real problem is startup, why not let it "idle" like a nitro (just set your throttle trim up a little) and then just grab all the throttle you want to take off. If you can't really use the ESC brakes on a direct drive anyway then it seems like a natural fit, no?
The problem with a clutch and this setup is, current clutch designs are up on the factory drive train where torque levels are much lower. How do we design a clutch that is inline with the shaft to handle the higher torque?
ESC brakes work fine with this setup. I've never had a problem with that aspect.
