12.30.2007, 10:20 PM
Originally Posted by Revracer View Post
what kind of torque will i get out of it? and i understand that the mm is a better speed control. my problem is im doing this on a budget. the ammo will deffinetly stick. so with the 3s for right now. might end up with a mamba max later on though. but im curious to the acceleration ill get from it. i want to be able to do wheelies.
Well, considering the mm is 5-10 bucks more expensive than the vxl, it is no contest, the mm is much better! You should be happy with the power, wheelies should happen easily. Your budget should be able to handle the mm/ammo setup. What batteries are you going to use?
