sikeston34m
sikeston34m's Avatar
01.29.2008, 07:55 PM
My motor has an 8mm shaft on one side of the motor and a 10mm shaft on the threaded side. I want to shave down the 10mm shafts into a 8mm shaft to match. Heres my motor- http://www.hobbycity.com/hobbycity/s...idProduct=4907
My drivetrain is very tough. I havent heard of anyone ever having issues with with their warhead diffs/bevels. I should be fine. I am going to replace the cvd pins in the arm cvd's because their very worn and Im afraid they'll snap like a twig under the huge stress they're about to under go.
BTW: Ill look into that 8mm metal revo yoke. Kinda pricey for just one yoke but I guess it'll do.
You might get by with using the prop adapter as long as you put it to work running the front wheels. If you point it toward the back to handle the majority of the load, it's not gonna live very long.
I know you are budget minded with this project, but take a look at your diff options. Run what ya got, and if they don't hold up, then upgrade to toughen them up.
I thought I had the diff area covered. My E Revo has almost $300 bucks worth of diff parts. The Best I could find. I've never heard of anyone having throuble like I have encountered, but at this point, My Revo will blow the rear diff pinion bearings in less than 2 packs on 6S. This is what I get for doing a custom motor wind. The custom motor makes alot more Torque than the factory winds. It's a 4 turn wind using 6 strands of 22Ga. wire with a Wye Termination. Big Power Bonus. I'll soon be doing a different diff setup. I have some ideas on how to fix it.
Because of the HUGE amount of torque that you're going to be making, you will encounter problems that your slower buddies don't run into.
Also, keep in mind that not just any ESC will run an Outrunner Motor in a MT Application. They have special needs. I use the Quark 125 amp ESC. I have also used the 80amp Quark with really good success.
