Superemaxx89
02.19.2005, 05:05 PM
Originally posted by ryanvm777
the switch might not allow as much current to go threw when your truck is on.
Depends on which switch you buy...like most things some are better than others.
Originally posted by Serum
It will not harm your controller....With brushless you need the to shorten the cables to a minimum too
Read here
Trust me, when i post pics i will probably have the shortest wire length on the forum.
Part of the reason why spikes are more harmful is because they are exposed. This happens because you don't have a solid connection (shaky hand, not enough metal to metal contact), once the plugs are connected, then you turn on the switch, you should not get a spike.
