Happywing
02.04.2008, 10:48 PM
The MM also did get hotter than I liked. Run a fan over it and get the settings correct and you should have very minimal cogging and good overall running.
Hey TD - If you don't have holes in the MM case already, do that. It really helps cool it down. Blowing a fan through those holes also helps big-time. You can put a hole in the bottom of the case and have fans on top and bottom too, if it will fit.
