VintageMA
VintageMA's Avatar
02.08.2008, 10:47 AM
Originally Posted by fkadir View Post
Thanks guys for all the help and advice.
VintageMA, so the battery tray is only mounted to the spacer and not directly mounted onto the chassis?
Yes - that is correct. This allows you the flexibility of being able to move the battery tray around a little bit to find the best balance front to back and side to side.
I used 4 screws through the chassis into the spacer and 4 screws through the battery tray into the spacer and it is mounted rock solid - better than any homebrew battery tray I've tried to make in the past.
I actually use the MaxAmps 5000mAh packs and not the Flightpower packs, so Mike made a battery tray for me that fits my packs perfectly - it measures a little shorter than the tray for the flightpowers.
Also - don't forget to drill pilot holes just a little smaller than the screw you will be using.
“Everyone has a right to be stupid; some people just abuse the privilege.”
