bdebde
That's All Folks!
bdebde's Avatar
02.14.2008, 10:46 AM
Originally Posted by orangecrush View Post
I made sure the receiver was binded with the new transmitter.
Then I went into programming mode using the transmitter and set the end points for full forward and full backward.
Is that what you meant?
Thanks,
Mark
Yes that is what I meant.
Were you able to hold full throttle for several seconds while doing the autotune? I never ran the autotune on mine because I never had the space to hold full throttle for several seconds around the house/yard. I also had trouble getting it to run when setting autotune from the software (try doing it with radio). Try resetting the controller to defaults and start over (endpoints too), if you can't get the autotune to work, don't use it.
