orangecrush
04.20.2008, 12:22 PM
Originally Posted by Serum View Post
You know this 'feature' in the MGM controller where the actual throttle position determines the speed the motor is running at?
so if you go from WOT to 5 percent, the car brakes as hard as it can to make the motor turn at 5 percent.. it might be an explanation..
Actually, if it was working that way, it would actually work correctly. Unfortunately, there is a "freewheel" in between throttle and brake.
Do you have the "frewheel" option switched on? I remember that people had issues getting this to work.
Yes, should I turn it off?
