Serum
Serum's Avatar
09.14.2005, 12:08 PM
okay, this here are some facts;
the conversion includes a 1 speed shaft, it is locked in 1st gear, and you can brake on the motor. (and drive backwards as well) with a few mods, you can lock it in 2nd.
You can use the standard transmission, (2speed) with a Y-cable you can split the speedo and the brake servo. (make sure the reverse on your esc is disabled) the motor is no longer able to slow down the vehicle, because of the one way bearings that are in the transmission.
You can also add the reverse module with the last cald option, not needed for the BL conversion..
If you have got any other q's feel free to ask them..
