05.11.2008, 08:41 PM
Originally Posted by azjc View Post
if the rest of your trucks setup remains the same your runtime will increase due to the increased voltage will lessen the amp draw from the motor
This is wrong, more voltage to the motor will increase the amp draw, unless you alter the gearing to achieve the same top speed with both battery setups. 6s a123 on an 8xl will most likely run hot, due to increased rpm over ideal for that motor.
