azjc
05.25.2008, 06:14 PM
Originally Posted by blueb8llz View Post
yea his charger output are 4mm banana plugs. lemme get this straight. so he buys a teamcheckpoint balancer:
http://www3.towerhobbies.com/cgi-bin...&I=LXTSA5&P=ML
and then he buys an adapter according to the lipo he chooses to get. so the link you sent me those adapters will plug into the right side of the teamcheckpoint balancer? so all chargers uses the same lipo balancer harness but its just the lipo packs that has different plugs? if this is correct, does he charge the lipos after balancing or does that balancer charge at the same time. see thats whats confusing us. my hyperion 0606i charger has power leads and balancer so i can do both at the same time where as his charger uses one output for both the power and balancer.
in order to use those adapters he would need to buy a hyperion style balancer your builtin balancer in your your charger would work, but if your friend wants to buy the TCP balancer he could only use them on those packs, if he wants to be able to buy different styles of packs I would get the Hyperion LB10 balancer
http://www.impaktrc.com/product_info...oducts_id=1679
