Mod Man
05.26.2008, 07:46 AM
The shaft is really presseed in place TIGHT! So, I cannot tell if it spun or not.
I think I will weld it just to make sure.
The weld will be at the rear tip of the shaft where it passes through the rear plate.
I will grind a notch in the plate and shaft tip, then fill that notch with weld and quench it to cool the shaft and prevent any heat related bearing damage.
Matt
