Mozzy
Mozzy's Avatar
06.25.2008, 07:22 PM
Ok, yes, you def need paddles & a smoother area to run.
What I'd do to find the binding is put the car on it's lid & disconnect the servo arm & move it yourself. Then as you go through the steering mechanism, disconnect things as you go & see if it frees up.
I'd remove ball links from steering knuckles & start there, if it binds, you know where to look.
Good luck.
Losi SCTE SC4 Pro 4000kv, Tekin RX8, 2S
MP7.5 Kanai III Tekno Neu 1515/2.5D 1700kv MM 4S
LST 2 Carbon CC 1717 1Y 1580kv MM 6S
Futaba 3PKS Spektrum Pro
