Sammus
Sammus's Avatar
08.19.2008, 04:45 AM
Originally Posted by tc3_racer_001 View Post
whats decent for clay racing? ive got 50K at the moment.
Depends a lot on the vehicle. I know the OP is asking about centre diff weight, but for an example about how much it can vary - in my old savage I used to run 100k or 300k, but in my buggy (basically the same diffs) I run between 3 and 10k depending on the environment.
I think it basically comes down to diff ratio, input torque, and the rotation inertia of whatever is connected to the diff output (ie, size of wheels)
If ALL your tires balloon like mad at the same time, changing the centre diff oil won't do a thing - not much you can do here short of strapping the tyres.
If its just your front wheels are ballooning when you take off, then you need to go heavier in the centre.
If its just one side that is panning, then you need to change the front/rear diff weight, and possibly the centre too.
Note that a lot of people have recommended diff weights for various vehicles we convert, and theyre normally talking about running nitro. Electric motors have about a billion times more torque from zero rpm, and thus to are much more prone to give the diff a workout - basically means either go heavier oil (and sacrifice some of the action of the diff), or go easier on the throttle.
In general (assuming 4wd) you want heaviest in the front, and the more traction you have, the tighter/higher weight diff oil you would normally want to use. If your diffs are unloading too easily (ie one tyre is ballooning when the weight is shifted from it) then you should up the oil weight.
