Sammus
Sammus's Avatar
08.26.2008, 10:16 PM
Which way do you have the tranny pointing? If you have the slipper pointing forward the gear may not clear. I run the 50t mgt spur and it fits fine with the tranny pointing backwards. I am using the erevo motor plate and motor mount though, but that would not affect the orientation of the spur.
The tranny is pointing with the spur at the back, wont fit in the other way. I'm really confused, there is a cutout in the chassis where the spur gear is, but just not enough. are there meant to be spacers or anything under the tranny?
Originally Posted by bruce750i View Post
Could it be the different offset of the spurs? Or a diameter thing as stated?
I'm not sure the offset is different, and the diameter of the gear I'm using is smaller than what is stock...
why did you not keep the original MOD 0.8 (32 pitch)????
I build the tranny from spare bits, I never had the original 32P gears. Plus I have about 20 suitable mod1 pinions and spurs at home, so it made sense to try and use them.
I'll have to get some pics up... will do soon.
