joeling
joeling's Avatar
08.31.2008, 10:35 PM
I'm pretty handy with a soldering iron but I can't unsolder SMD parts as well. What I did was to use a brutal wire cutter & chomp away at the chips until I severe the connections & destroy the parts. I did use a desolering gun to attempt to suck away the excess solder for show show only. Couldn't be sure how much it helped. I did however use a multimeter to check that there is no short between pads but also take note that some pads are common.
Originally Posted by slimthelineman View Post
im not steady handed enough to unsolder the tiny @$$ parts on the pcb could i run an external bec and maybee see some extended life from my next v2?
In my experience, running an external BEC without the mod will not work. U need to remove the parts. I was already running an external BEC in my V1 buggy conversion when it died & I had to follow BrianG's way.
Regards,
Joe Ling
Hyper 9e Medusa 4S, Savage 5S MMM 8XL, Jammin' 4S Neu MMM, X2 Ninja JX, X2 MMM 5S Neu, E REVO Medusa 6S
