speedsecret
09.10.2008, 10:48 AM
ok i have a brushless LSP with the novak kit so i will try to help
the 5.5 is to high a kv even the 6.5 is too
i have a 6.5 geared 11/48 at 11.1v the top speed is 36mph
i race so this is alittle higher than i want but it stays very cool
power is supriseing good
the only other parts you will need to get started is a plastic center diff gear and a pinion
im useing a castle creations bec since in only useing one battery lead and a 3 cell novak smart stop for the lipos
im getting about 20-30 min of run time on a 5000mah lipo on tight tracks
here is mine http://www.rc-monster.com/forum/showthread.php?t=14909
thank you for your replay guys .
so maybe i should go on the 7.5 motor?
and if i will use a 4s lipo it will cause the motor to get warmer then with 3s?
also a friend of mine advice me to go on the mamba monster esc a neo motor
so what you think?
