portyansky
10.19.2008, 02:41 PM
Now I had to attach the motor to the mount, but before I did that I had to dremel a flat spot on the shaft so that when I put on the clutch assmbley, the grub screw (which was not included in the kit, they must of forgot) had a place to sit flat.
After:
Now ataching the motor. The screws provided were not long enough to tighten the motor properly which caused me to strip a hole in the motor, so I had to tap the motor for a bigger screw (Left of the pic). So after I learned my lesson on the left I used a longer screw for the right.
Assembled:
Now its time to attach the electri-clutch (if you look at the above pic, you will notice a slot, this was done so your allen key could fit and reach the grub screw):
Assembled:
Now to attach the motor and mount. This gets attached just like the nitor mount, except you dont have to use the star washers.
Now the battery tray and straps had to be installed:
Assembled:
Installed:
