david lamontagn
10.20.2008, 03:51 PM
Neither the quark nor the MM will run 4s without a bec.
The quark is a good esc. It has the same fets as a MM. I think the programming is better in the quark, as it will run any motor, and runs them all well. However the MM has a better heatsink. I run the quark 125b on 6s in a buggy and have had success. I also run one in an emaxx with a plett maxx and 4s lipo. And in a slayer with a hacker c50 13L on 5s.
How cheap is your good deal?
$120.00 but the external casing have been remove and replace by a transparent shrink wrap.
You say that i need a UBEC on 4s with the Quark?????????
And realy, is i need to do all the internal modifs and use the RCM heat sink if i only run 4s in a crt.5????
