11.05.2008, 12:55 PM
Originally Posted by Dagger Thrasher View Post
No offence, but after all the issues the MMM has had and all the work Patrick/CC have done to get them up to scratch, I *seriously* doubt that Patrick's about to let thousands of MMM V3s leave the factory if they apparently have such an obvious flaw. If there actually was a problem, there's no way he'd be daft enough to say there wasn't after they've tested the issue to death.
Nothing against CC, but they have still not cured the fan wiring issue. Simple fix to do when you get the esc, but something simple like that should be addressed before the case design was finalized. The MMM design and case are quite a bit different to CC other products, save for the sidewinder. No enough clearance, or a specific area for the fan wire.
Not trying to say that you are wrong Dagger, but the MMM is not perfected yet... I still see flaws that can cause the unit to stop working, or at least not survive for a sufficent service life without failure.
Patrick said that they could not duplicate the short in this case, and hadn't witnessed it. That doesn't mean it can't happen (and IMO eventually it will happen if both bullets are touching the aluminum conductor - it is only a matter of time). Personally, I would not even consider running a controller that has this potential issue beyond initial testing - I would address it before any extensive driving. I don't care who says its OK - it looks like a short waiting to happen. I suppose if(when) it does short, it will be covered by warranty, but the batteries won't be covered(or the chassis and melted Lexan body). Just my opinion based on 8 or so years of brushless car/truck use. :)
Well put Mike, all the testing in the world will only show up some problems. The proximity of the bullets to the heatsink is an issue, the heatsink needs to be smaller, or the board needs to have a bit more room in those areas... I like the bullets on the pcb, at least on the motor side.
Originally Posted by hoovhartid View Post
pedifile...
"1. pedifile
Michael Jackson, R. Kelly
Dont go to Neverland Ranch "
First entry in the urban dictionary, made me laugh a bit...
