Sammus
Sammus's Avatar
11.29.2008, 08:03 PM
I put a spool in the centre and it just makes the diffs strip even easier. I'm pretty sure the servo's are the same. It's a stupid setup, they should have used a single mid size or normal size servo, they just wanted to use two so it looked scale.
The ring/pinion stripping was solved by using metal ring/pinion in the mlst2, but the internal gears are still plastic and are pathetically weak. If you run a centre spool you will definitely have diff problems, even with a totally stick nimh setup. Not only that but depending on outside temps you will be constantly thermalling the esc - I thought mine was faulty and losi just said 'dont use full throttle much and it wont happen'. nice fix lol.
