12.25.2008, 08:28 PM
Originally Posted by wallot View Post
oh almost forgot that BL Savage will come out in January 2009 which may be the best bashers option.
Unless they fix the diffs, savage is still flawed. Plus I dislike the battery mounts, and the general layout is not really weight optimized.
If losi makes a bl lst, we will have a winner. Honestly, tdr makes a single speed adapter and a motor mount. Swap in the FOC kit losi makes and you have a solid super smooth single speed tranny and motor brakes. Ditch the brake and reverse servos and there is good room for a battery tray. Much stronger than a revo or maxx, strongest drivestrain I have seen, plus it has the motor mounted transversely which cures torque twist.
I have converted all of the above and the savvy is going up for sale soon. I will keep the flm savvy, but I need the bulks flm sells, I have fixed too many savage diffs. At least the X cases are easier to open, but not as easy as the lst. The lst does not need easy to access diffs, casue once they are in the al cases they are done till they wear out. If you run 40 series wheels/tires they will be fine, if you run std mt stuff they will last forever. No better truck, and no need to upgrade the lst2. Maybe rpm arms, but I dislike the use of the original lst rpm arms with shims to fill the wider hubs of the lst2.
