brushlessboy16
brushlessboy16's Avatar
01.15.2009, 01:17 PM
http://cgi.ebay.com/NEW-SLASH-STAMPE...3%3A1|294%3A50
Its gonna take some serious modding to get the rustler trans on an evader..Transmission has a wayy bigger mounting surface, and different driveshafts etc.
ok, first thing get the alloy idler gear from the nitro evader, it fits. second get the diff gear from the associated rc10 B2, and the B2 diff rings. the bearing size is also different get a 5X8 bearing. do all that and you will have no problems going 60 with it, just as long as you maintain the diff and slipper. i have the mamba 6900 and i ran it with 7 cells and got 48 mph with it, and i consistantly do speed runs on my evader... LASTLY this is not neccassary but there is a someone out there that makes a custom alloy diff gear for the evader.. go to www.arrow-rc.com , thats totally up to you if you want one.
edit: im sure you know but make sure you lube up the diff balls with clear silicon grease and use black grease on the outside of the gear where it mesh's with other gears
