Joe Ford
Castle's Chaos Corner
Joe Ford's Avatar
03.10.2009, 04:21 PM
Originally Posted by SpEEdyBL View Post
I run mine on 5s as well w/o problems and its the same rpm as the 2200 on 6s. Change the voltage limit of the 2650 to 5s. That would make more sense - unless there is something you are not telling us (why a 1515 size motor would handle more rpm)???
Guys this is NOT GOING TO BE DEBATED. FOLLOW THE RULES OR PAY WHEN YOU BREAK IT...PERIOD! WE ARE NOT GOING TO CHANGE OUR RATINGS SO YOU BETTER DECIDE WHETHER YOU WANT TO PAY IF SOMETHING HAPPENS OR NOT!!!
READ PATRICKS POST...IF THAT ISN'T CLEAR ENOUGH YOU'VE GOT BIGGER PROBLEMS...
Speedy...you need to re-read post #39...NOWHERE in there did I say that 5s on a 2650 is over 60k. I said that on 6s at anything over 22.64v under load it would be over 60k. You also need to re-read the part about the wattage handling ability of the shorter motor being less than that of the longer can motor, and how this can cause motor failures IF THE PERSON DOESN'T KNOW WHAT THEY'RE DOING. We want people to succeed...if they follow what we say they will. If you guys want to experiment that's your prerogative, but expect to pay for it if you break it...again read Patrick's post!
Joe Ford
Product Specialist
