Mikey007
03.24.2009, 05:58 PM
If you stand the lipo on its side you can fit plenty more than 4s. I can fit 10s worth of the 3200 fp cells in mine...
I guess it depends on cell width and gearing. Std 45mm wide cells (most available cells are about that width) still leave enough room to get most gearing options in there, if you use the 52t spur.
Linc the fp 3200 is only a 25c. Do you think I will exceed the amp draw of this battery? I have enough room for this battery no problem, and could run the 5000 with spacers under the motor mount, but did not like how it looked. I do have the 52t spur and the 2 speed is still intact until I blow the living hell out of it!
Mike
