whitrzac
Can't catch this...
whitrzac's Avatar
03.24.2009, 07:38 PM
What radio are you using? Sounds like you may need to zero everything to do with the throttle channel and recalibrate the radio to the esc. I am not familiar with tekin products, but if it works one way and not the other you may have a controller issue. Do you have the reverse % set very low?
Would you mind posting a picture of your settings? If it isn't your settings, the only thing that comes to mind would be binding. Push the thing in reverse and see if it rolls as smoothly as forward. You could have a drivetrain problem.
its a JR XS3(75mhz fm), it has the same functions/adjustments as the spektrum DX3 without the whole spektrum thingy. I'm 100% positive that the setings on the controler are right...
the drivetrane isn't binding at all, so thats not it.
EDIT: I found the problem, the CC bec is set at 5.1v from the factory.I hooked up the esc without the external bec and problem solved...
anyone have a castle link I can barrow?
