04.06.2009, 01:22 AM
Originally Posted by NoControl View Post
So it's either impossible or difficult to remove the xh connector, so that all I have is the wires, and the battery, then install them in a hyperion white connector without buying the "special" hyperion connector with wires or the xh board?
The type of crimped on pin that the xh connector uses will not phsically fit and clip in a hyperion connector. You either have to splice the hyp tap on, or remove the shrink and solder a new harness on. I would suggest an adapter, cheapest and simplest way out.
