05.02.2009, 12:26 AM
Originally Posted by clowkoy View Post
I've done this to my Futaba 2PL-FM but I have to bypass the diode inside. One problem with this is that you cannot charge at rates higher than 1 amp or the batteries will overheat or false peak (I am using Duracell/Energizer 2500's) on my 0610iNET. I just slow-charge it with my trusty Tekin 112 at 200-250mah.
I use the same cells and noticed the same thing. Since I'm not usually in a hurry, I charge at 0.5A, or use the auto-NiMH setting on my Hyperion 7i. I never drain them totally down so it usually only takes 1-1.5 hours to top them off.
