Freezebyte
05.09.2009, 07:51 PM
Yeah, the lipos will recover voltage a bit after they sit. Sounds like you are ok. Did the MMM make 4 beeps when you switched it on? It should do its arming tone, then beep 4 times (to indicate 4 cells) if you have the auto lipo set correctly. It is a shame that hpi did not include a castle link with the flux...
Yeah, I'm pretty sure it beeps 4 times after the initial Doo dee doo and then it does another doo dee doo.
I guess im confused, is voltage not directly related to mAh capacity? Everywhere on the web it ALWAYS states don't go below 3.0V for LiPo's but it says nothing about the lowest % of capacity to use or don't use. Some guys say you should never have less then 10% of the packs capacity left. Well I obviously went below that according the charger.
