05.23.2009, 11:18 PM
A little update, had to swap some of the equip out of the buggy, so I decided to just throw in a MM and see how it did with the Novak Hv. Way too much wiring to be done on the ssb, and I have to run a ubec over 8 cells nimh (so pretty much any voltage I will run will need the ubec).
Lets just say I adjusted every setting on the MM and even played with the M8 settings too, trying to get the hv motor to start well and run well. I then swapped the 9l back in and had a few fun minutes till I snapped a stock pede driveshaft.
So I have learned that trying to get a novak to work with a MM and a heavier vehicle is a waste of time. The 9l does great, goes faster with the same gearing!?!?! (2700 kv vx 3100 on the hv?) and has more power, even with the timing set on 10 compared to the timing set on 20 for the novak. I did not get a chance to run a full pack thru with the 9l so I have no idea on temps.
I have a feeling this vehicle will get the 1509 4500kv motor on 2s lipo and the novak will go in something else with the ssb. I am going to put alot of my rollers together in the next few weeks... Gotta get some of these beasts moving!
