05.24.2009, 11:39 PM
It may be a bit bulky to do what you want with it. You could "window" the tvp like the flux does and stick the motor out a bit. I made a simple L bracket mount that would allow a 36mm motor to fit almost on the stock nitro mount area and was adjustable thru 14-20t pinion with a 47t spur. If you go to the 44t flux spur you will have more adjustability than I did.
