Ryu James
Ryu James's Avatar
06.08.2009, 09:40 PM
Originally Posted by exawatt View Post
i used a inferno diff kit from the 777sp2 and the 46t plastic kyosho spur. all worked well but you need to get the longer front center shaft. i dont remember what the partnumber is but i think it was 110mm i can check when i get home.
perfect. can you let me know on that. i have decide to just run single speed so i knew i would need the longer drive shaft. even if you dont have a part number just the what model its from would help.
also, i dont have my gt2 yet. just ordered thru amain. i am wondering what the pinion shaft size is on the front and rear gear boxes. you know that shaft that comes out of the gearbox and connects to the drive shaft. is it 5mm or 8mm?
Jammin SCRT10 Neu 1512 1y
