Thread Tools Rating: Thread Rating: 16 votes, 4.25 average. Display Modes
Ryu James
Ryu James's Avatar
06.24.2009, 03:11 PM
so here is the latest.
i got my 10s TP packs today and the monster truck has been shipped back so they can now send the correct buggy out to me.
and here is the kicker. i decided to upgrade in the motor department and i picked up a Neu 2230 1y! WOOHOOOO!!!! After considering the weight of the vehicle the size of the 2215 i just thought it might be a little underpowered so i went with the 2230. there is plenty of room on the chassis. i may use the 2215 still. it just depends on what does the job the best.
get this - the Neu 2215 is 3.3" long and dia. of 2.26" and 25 ounces.
the 2230 is same dia. but 4.7" long!! and 48 ounces.
i was told the 2215 does a constant of 2500 watts which is about 3hp. does that mean the 2230 is good for 6hp with the 5000watts?
neu2230
here are pics of the new TP packs. essentially the same size as 20 of my NeuEnergy 5s packs. they weigh 42 ounces which will balance the chassis perfectly if i use the Neu 2230 motor that wieghs 48 oz since will have the motor on one side and the lipo on the other side and the esc will be by the battery and will probably weigh 5-8 ounces depending on which one i get.
i cant wait to start on this thing.
tp10s2
tp10s1
also, while i had the monster truck here i looked at the center diff. it is not a viscous diff. its just a locked spur gear so equal drive is sent to front and rear. i found a spur gear that i will think will work to replace the stock one. it has the right hole pattern and right size holes i just need to find out if the holes will match up.
redcatcenterdiff
1/5spurgear
Jammin SCRT10 Neu 1512 1y
