starscream
RC-Monster TQ
starscream's Avatar
09.03.2009, 11:47 PM
Longer runtimes as in what? You want more running time between battery swaps? If so, you aren't going to, running higher voltage does not really bring longer runtimes, it does bring lower temps though.
Do you have real world experience to justify your statement?
Just looking at your statement logicaly, it doesn't make sense. If a higher voltage system produces less heat then this simple fact alone is proof that higher voltage would provide longer run times. The lower voltage system's wasted energy, from heat, will reduce its run time. The difference of the two system's runtime may be small but it exists none the less.
My real world experience has been the higher the voltage, the longer the runtime. The difference in runtime isn't that much but is measurable.
Ha Ha
