superlapS15
09.27.2009, 06:32 AM
Originally Posted by Shark413 View Post
I think may be the motor was just bad, or didn't have enough torque for my setup. I have since been running a 2200KV MMM motor (truggy size) and the temps are great. I am running a Tekin 2000kv motor in my 8ight 2.0 truggy and it has been running great and no issues with the rotor. I also just recieved some of the Castle blower fans, and it fits righ on the motor and under the body with no clearence issues. It should help keep the temps down on those super hot days here in Socal.
I get the impression that rotor failures aside, the Tekin motor is far more reliable than the Tekin RX8 ESC.
My main interest in the Tekin motors lies in the low KV options available and the 4mm mounting holes. Neu has low KV motors, but I would be stuck with 3mm holes (I'm not going to try to tap 4mm holes) and the wires exiting out the rear of the can have caused some hassle in the past- similar to your problem with melting/splitting the wire covering, I melted all three! At the moment, my Neu 1512 2D is still holding together (despite some heat issues a few weeks back) and will remain in my 8ight, and the MMM/2200 combo I have lying around will go into the 8ight 2.0. When I try 6S/low kv, I will probably get a 1400kv Tekin motor to test and see how it performs, at least until Castle release a low KV motor (with 4mm holes, just in case someone is reading this!!! )
Temperature wise, I'm heading into summer here in Australia (South East Queensland) so any motor/esc is going to have a tough time. Generally though, it is the motor that runs hot for me, with the ESC only running slightly hotter in summer (10-15F hotter). I went to the track today to try a few ESC changes on my modified MM but a damaged wire/ripped off connector ended the day after only one lap of qualifying- I was hoping the changes I made to the braking power (decreased power, steeper braking curve with full braking from 50%) would help the 1512 2D run a little cooler. It seemed to run cooler on my track, but it really requires testing on a large track to confirm any improvement.
I did see that Castle have released their motor fan, but I'll be interested in first managing temps with my existing setups, then perhaps adding a fan for additional cooling and reliability. If I can get both my motors to stay under 150 after a 10 minute qualifier (including 2-3 mins warm up) I'll be quite happy. Adding a fan would then provide an additional measure of protection for the hotter months of the year.
You mentioned torque in your post- I'm curious to see how the 2200kv performs compared to the 2550kv Neu, the CC motor being a longer rotor/magnet/can design. I'm not really after speed, but I want to always have that 'punch' that electric provides. It may well be the case that the longer can motor provides that 'punch'/torque with less current draw, hopefully improving temps and runtime.
