J57ltr
09.30.2009, 09:32 AM
By connecting one + and one - together on each speaker and connect the remaining 2 terminals to 1 channel do the same for the other sub.. This will give you a single 4 ohm load on each side. Assuming the amp is only 2 ohm stable this is the max you can go. The other 2 channels will go to your component set. Most 4 channel amps have a built in crossover use that.
Jeff
