schofield
schofield's Avatar
10.19.2009, 12:56 PM
That much suspension is overkill. But it looks cool as hell, if you want to run it, then run it.
You may want to consider duals on the rear, or 14mm adapters and maxx size paddles. I've run those same paddles on a rustler in the snow, and it didn't go very far.
Either of those suggestions requires a very stout drivetrain, but I believe to be an effective snow machine you will need more traction.
ok so it is over kill. thank you. i kind of figured that but i had seen a car someone made into a snow vehicle with a 4 link system and solid/locked rear.
i wish i knew where that pic is it was out of some old RC magazine. it was really long. so i thought i could use the way an arm is connected and not have the side to side say a crawler has. my thinking is the was snow is all aver the place an not just smooth so i wanted the rear to be able to soak up bumps but then have each arm be able to move on their own to make contact with any random hole
kEEp It sUrrEAl
