jas21373
11.08.2009, 07:19 AM
Originally Posted by Matthew_Armeni View Post
If you're using motor brakes 5s is the highest I'd go due to voltage spikes. I'd also add some extra caps to be safe and a fan. If you run mechanical brakes, 6s will work on the MM with just a fan. An external BEC is a must of course on both.
I've try 6s on a MM ,it doesn't except the voltage.......wan't start up
