Freezebyte
11.10.2009, 03:23 PM
And you can get the bearing number right off the bearing too -- can even read it in your post. :)
That is an NMB (nippon miniature bearing) 625ZZ ABEC bearing. Chrome steel, double shield.
Manufacturer's web site:
http://www.nmbtc.com/bearings/
5mm x 16mm x 5mm
And I agree - -the bearing looks fine. Doesn't look like there is any issue.
It's both press fit and glued in place.
Wow, no wonder I couldn't hammer that sucker out, it didn't even budge. I'd basically have to destroy the bearing to replace it then? I took it to the LHS and my main guy their said it makes a little bit of noise and some resistance but it should be ok for a bit longer.
I should probably take a movie of me spinning it and you can tell me how good or bad the bearing is.
EDIT: Heres the video, tell me what you think. And whats up with the shaft being able to move back and forth like that? Is that bad?
[YOUTUBE]6bsIeIC2BHY[/YOUTUBE]
