Pdelcast
Pdelcast's Avatar
12.23.2009, 12:55 PM
Originally Posted by andywpj View Post
Hi,
i am sure R113ip can't work MM/MMM esc.
because R113ip is a PCM receiver, it build in pcm decoder IC , decoder IC work voltageic 3V ,output single voltage level between 2.6V~2.8V,
ESC can't identification right level. so sometime maybe work, maybe no.
you can solution issue.
just put a fail-safe in R113ip and MMM.
Well, the MMM only needs a logic level of about 2.0V to operate. So that's not the problem.
Patrick del Castillo
President, Principle Engineer
