Stoomstrijkijze
08.17.2010, 11:21 AM
BUT -- in sensorless mode the timing is limited to about 20 degrees of advance -- which is the same as "high" timing in the Mamba series.
In sensored mode, the timing can be set much higher (like "CHEAT" mode --) but the advantage only works with very poor performing motors (like the ROAR motors...)
Yes, but 10-15° timing advance should give you around 10% more KV's. Which means you can drop 1 teeth on the pinion (or maybe 2). Then you drive it in the tight, technical with 0° and 1 teeth lower = lower temps, more efficiency. And on the straights the timing goes up and you don't lose any speed than with your previous setup.
I don't own a Tekin system myself, but that's what read on the boards and it looks very promising.
